Inleiding
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Follow this guide to remove and/or replace the Taptic Engine in an iPhone 12 Pro.
Wat je nodig hebt
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
Press firmly to eject the tray.
Power off your iPhone before beginning disassembly.
Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Gereedschap gebruikt in deze stap:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the plastic screen bezel when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
Continue sliding up the right edge of the iPhone until you reach the top right corner.
Leave the pick in the top right corner before continuing.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Insert a second opening pick in the bottom left corner of the iPhone.
Twist both picks simultaneously until the left edge clips release.
Rotate your iPhone so the right edge faces you.
Open the iPhone by swinging the display up from the right side, like the front cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a spudger or a fingernail to disconnect the display cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Use a Y000 driver to remove four screws securing the front sensor connector cover.
Three 1.1 mm-long screws
One 1.4 mm-long screw
Swing the cover up from the left until the small clip on the right unhooks.
Remove the cover.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Use a Phillips driver to remove the four 1.6 mm screws securing the loudspeaker.
Use a Y000 driver to remove the two 1.4 mm long screws securing the SIM card reader connector cover.
Remove the SIM card reader cable connector cover.
Use the point of a spudger to pry the SIM card reader cable connector straight up and out of its socket on the logic board.
Use a Y000 driver to remove the three screws securing the SIM card reader.
Two 1.4 mm screws
One 1.1 mm screw
Remove the Taptic Engine cable connector bracket.
Gereedschap gebruikt in deze stap:Standoff Screwdriver for iPhones$5.49
Use a standoff or a small flathead driver to remove the 2.82 mm long standoff screw securing the SIM card reader.
Use the point of a spudger to pry the Taptic Engine cable connector straight up and out of its socket on the logic board.
Remove the three screws securing the Taptic Engine.
Two 2.8 mm long standoff screws
One 1.8 mm Phillips screw
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Answers community for help.
7 andere personen hebben deze handleiding voltooid.
