Ga door naar hoofdinhoud
iPhone 11 Pro Rear Case Replacement
Wat je nodig hebt
Video overzicht
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 2 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: stap 1, afbeelding 2 van 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Arty
14.647 Reputatie
85 handleidingen geschreven
3 opmerkingen
how much for housing iphone 11 pro ? Thank you
daddy - Antwoord
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 218
Altijd: 14,710
