Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Follow the steps in this guide to replace the display assembly in an iPad mini 4 Wi-Fi.
Note that if you would like to maintain Touch ID functionality or your replacement part does not include a home button, you should follow the screen and digitizer replacement guide, which includes removing and transferring your home button to the new display panel.
Wat je nodig hebt
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
Use the flat tip of a spudger to disconnect the display data connector from its socket on the logic board.
Disconnect the digitizer cable connector from its socket on the logic board.
33 andere personen hebben deze handleiding voltooid.
2 opmerkingen
why after replacement power button doesn’t lock screen, where is those smart cover sensor are located?
great guide but u dont discuss reapplying the adhesive strips .. which is very important.
