Ga door naar hoofdinhoud
iPad Mini CDMA Logic Board Replacement
Wat je nodig hebt
  1. iPad Mini CDMA Logic Board Replacement, iOpener Heating: stap 1, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, iOpener Heating: stap 1, afbeelding 2 van 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad Mini CDMA Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad Mini CDMA Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad Mini CDMA Logic Board Replacement, Alternate iOpener heating method: stap 4, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, Alternate iOpener heating method: stap 4, afbeelding 2 van 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Mini CDMA Logic Board Replacement, Front Panel: stap 5, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement, Front Panel: stap 5, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement, Front Panel: stap 5, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Mini CDMA Logic Board Replacement: stap 6, afbeelding 1 van 1
    • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
  7. iPad Mini CDMA Logic Board Replacement: stap 7, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 7, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 7, afbeelding 3 van 3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you may risk cracking the glass.
  8. iPad Mini CDMA Logic Board Replacement: stap 8, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 8, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 8, afbeelding 3 van 3
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  9. iPad Mini CDMA Logic Board Replacement: stap 9, afbeelding 1 van 1
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
  10. iPad Mini CDMA Logic Board Replacement: stap 10, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 10, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 10, afbeelding 3 van 3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
  11. iPad Mini CDMA Logic Board Replacement: stap 11, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 11, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 11, afbeelding 3 van 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  12. iPad Mini CDMA Logic Board Replacement: stap 12, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 12, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 12, afbeelding 3 van 3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  13. iPad Mini CDMA Logic Board Replacement: stap 13, afbeelding 1 van 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  14. iPad Mini CDMA Logic Board Replacement: stap 14, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 14, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 14, afbeelding 3 van 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  15. iPad Mini CDMA Logic Board Replacement: stap 15, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 15, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 15, afbeelding 3 van 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  16. iPad Mini CDMA Logic Board Replacement: stap 16, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 16, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 16, afbeelding 3 van 3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  17. iPad Mini CDMA Logic Board Replacement: stap 17, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 17, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 17, afbeelding 3 van 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  18. iPad Mini CDMA Logic Board Replacement: stap 18, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 18, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 18, afbeelding 3 van 3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  19. iPad Mini CDMA Logic Board Replacement: stap 19, afbeelding 1 van 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  20. iPad Mini CDMA Logic Board Replacement: stap 20, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 20, afbeelding 2 van 2
    • Slide the top right opening pick around the corner to fully release the top edge of the glass.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  21. iPad Mini CDMA Logic Board Replacement: stap 21, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 21, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 21, afbeelding 3 van 3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  22. iPad Mini CDMA Logic Board Replacement: stap 22, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 22, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 22, afbeelding 3 van 3
    • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
  23. iPad Mini CDMA Logic Board Replacement: stap 23, afbeelding 1 van 1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  24. iPad Mini CDMA Logic Board Replacement: stap 24, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 24, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 24, afbeelding 3 van 3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
    • Antennas
    • Home button cavity
    • Digitizer cable
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  25. iPad Mini CDMA Logic Board Replacement: stap 25, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 25, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 25, afbeelding 3 van 3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  26. iPad Mini CDMA Logic Board Replacement: stap 26, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 26, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 26, afbeelding 3 van 3
    • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
    • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
    • Insert the pick slightly deeper and work it back toward the home button.
    • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
  27. iPad Mini CDMA Logic Board Replacement: stap 27, afbeelding 1 van 1
    • Reheat and reapply the iOpener to the top bezel of the iPad.
  28. iPad Mini CDMA Logic Board Replacement: stap 28, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 28, afbeelding 2 van 2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
    • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
  29. iPad Mini CDMA Logic Board Replacement: stap 29, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 29, afbeelding 2 van 2
    • Lift slowly and gently to further detach the adhesive along the lower edge.
  30. iPad Mini CDMA Logic Board Replacement: stap 30, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 30, afbeelding 2 van 2
    • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
    • If reusing the front panel assembly during reassembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
  31. iPad Mini CDMA Logic Board Replacement: stap 31, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 31, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 31, afbeelding 3 van 3
    • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
    • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
    • Return the front-facing camera housing to its recess in the rear case.
  32. iPad Mini CDMA Logic Board Replacement, LCD Assembly: stap 32, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement, LCD Assembly: stap 32, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement, LCD Assembly: stap 32, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Small pieces of foam tape cover the top and bottom right-hand screws securing the LCD to the rear case.
    • Use tweezers to peel up and remove the rectangular piece of foam tape covering the top right LCD screw.
    • Remove the triangular tape covering the lower right LCD screw.
  33. iPad Mini CDMA Logic Board Replacement: stap 33, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 33, afbeelding 2 van 2
    • The top left LCD screw may be covered by adhesive tape from the front panel.
    • If the tape is present, use the flat end of a spudger to pry the tape up and away, exposing the LCD screw beneath.
  34. iPad Mini CDMA Logic Board Replacement: stap 34, afbeelding 1 van 1
    • Remove the four 3.9 mm Phillips #000 screws securing the LCD to the rear case.
  35. iPad Mini CDMA Logic Board Replacement: stap 35, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 35, afbeelding 2 van 2
    • Use a pair of tweezers to peel up the small piece of tape connecting the LCD frame to the right speaker.
  36. iPad Mini CDMA Logic Board Replacement: stap 36, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 36, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 36, afbeelding 3 van 3
    • A thin strip of foam tape on the LCD frame is covering a piece of tape connecting the LCD to the panel beneath it. To proceed, you'll have to break and peel up some of the foam tape to expose the tape hidden beneath.
    • Use a pair of thin tweezers to pull up the top of the foam tape surrounding the LCD.
    • Be careful not to touch the LCD with the tweezers, as you may damage the display.
    • Use the tweezers to peel the foam tape up to expose the top of the LCD.
  37. iPad Mini CDMA Logic Board Replacement: stap 37, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 37, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 37, afbeelding 3 van 3
    • Insert the tip of a spudger between the LCD frame and the tape on the top of the LCD.
    • Slide the spudger along the space between the LCD frame and tape, separating the tape from the LCD frame.
  38. iPad Mini CDMA Logic Board Replacement: stap 38, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 38, afbeelding 2 van 2
    • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
    • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
    • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
  39. iPad Mini CDMA Logic Board Replacement: stap 39, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 39, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 39, afbeelding 3 van 3
    • Insert the guitar pick into three more locations down the left side of the LCD and bend it over in each location, to slide the LCD over to the right side of the rear case.
  40. iPad Mini CDMA Logic Board Replacement: stap 40, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 40, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 40, afbeelding 3 van 3
    • Now switch to the right side of the LCD, and pry with the guitar pick in several places along the side to shift the LCD back to the left.
    • Repeat this and the previous step a few times, until the LCD is easily moved left and right.
  41. iPad Mini CDMA Logic Board Replacement: stap 41, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 41, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 41, afbeelding 3 van 3
    • In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath.
    • Insert the flat end of a spudger between the LCD frame and the metal backing plate.
    • Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
  42. iPad Mini CDMA Logic Board Replacement: stap 42, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 42, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 42, afbeelding 3 van 3
    • Starting at the top right of the device, slide the spudger in between the LCD frame and metal backing plate, which will separate the adhesive as you push.
    • The goal is to separate the adhesive, not to pry the LCD up, so keep the pointed tip of the spudger as low as possible to prevent bending the LCD.
    • If inserting the spudger causes the corner of the LCD to bend up, repeat the steps with the guitar pick to further loosen the adhesive.
  43. iPad Mini CDMA Logic Board Replacement: stap 43, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 43, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 43, afbeelding 3 van 3
    • Repeat the previous procedure along the top of the LCD.
    • Insert the flat end of the spudger between the LCD frame and metal backing plate and gently push the spudger in across the top of the device, separating adhesive.
  44. iPad Mini CDMA Logic Board Replacement: stap 44, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 44, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 44, afbeelding 3 van 3
    • Continue with the left side of the LCD: insert the flat end of the spudger between the LCD and shield plate and insert the spudger as far as it will go.
    • At this point the LCD should be loosened from the adhesive holding it. If it is not, re-insert the spudger on the right side or top to fully free the LCD.
  45. iPad Mini CDMA Logic Board Replacement: stap 45, afbeelding 1 van 1
    • Lift the LCD up a couple inches from the rear case to ensure it's free from the adhesive.
  46. iPad Mini CDMA Logic Board Replacement: stap 46, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 46, afbeelding 2 van 2
    • Two wide strips of tape connect the LCD to the speakers.
    • While holding the LCD with one hand, Insert the flat end of a spudger into the gap between this tape and the left speaker.
    • Gently pull the LCD away from the speakers while rotating the spudger outward to separate the tape from the speaker.
  47. iPad Mini CDMA Logic Board Replacement: stap 47, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 47, afbeelding 2 van 2
    • Insert the flat end of the spudger into the gap between the right speaker and the LCD tape.
    • While pulling the LCD away from the speakers, rotate the spudger outward, widening the gap and releasing the tape from the speaker.
  48. iPad Mini CDMA Logic Board Replacement: stap 48, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 48, afbeelding 2 van 2
    • Flip the LCD over and rest it on top of the front panel glass.
    • Do not attempt to remove the LCD from the iPad, as it is still connected by its data cable.
  49. iPad Mini CDMA Logic Board Replacement, LCD Shield Plate: stap 49, afbeelding 1 van 1
    • Remove the following screws securing the LCD shield plate to the rear case of the iPad:
    • Two 2.6 mm Phillips #00
    • Thirteen 1.7 mm Phillips #00
    • One additional 1.7 mm Phillips #00 on some devices.
  50. iPad Mini CDMA Logic Board Replacement: stap 50, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 50, afbeelding 2 van 2
    • Insert the flat end of a spudger underneath the center of the LCD shield plate from the bottom end of the iPad.
    • Pry up on the spudger to free the plate from the sides of the rear case.
  51. iPad Mini CDMA Logic Board Replacement: stap 51, afbeelding 1 van 1
    • Remove the LCD shield plate from the iPad.
  52. iPad Mini CDMA Logic Board Replacement, Battery Connector: stap 52, afbeelding 1 van 1
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
  53. iPad Mini CDMA Logic Board Replacement: stap 53, afbeelding 1 van 1
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  54. iPad Mini CDMA Logic Board Replacement: stap 54, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 54, afbeelding 2 van 2
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
  55. iPad Mini CDMA Logic Board Replacement, LCD: stap 55, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, LCD: stap 55, afbeelding 2 van 2
    • Use a plastic opening tool to pry the LCD connector from its socket on the logic board.
    • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
  56. iPad Mini CDMA Logic Board Replacement: stap 56, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 56, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 56, afbeelding 3 van 3
    • The LCD is still connected to the rest of the iPad by two wide strips of adhesive tape that run up from the inside of the rear case to the front bottom LCD frame.
    • While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side.
    • Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
    • It may help to twist the spudger, to spread the gap the rest of the way and separate the LCD from the tape.
  57. iPad Mini CDMA Logic Board Replacement: stap 57, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 57, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 57, afbeelding 3 van 3
    • While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape.
    • Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
  58. iPad Mini CDMA Logic Board Replacement: stap 58, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 58, afbeelding 2 van 2
    • Lift and remove the LCD from the iPad Mini.
  59. iPad Mini CDMA Logic Board Replacement, Front Panel Assembly: stap 59, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, Front Panel Assembly: stap 59, afbeelding 2 van 2
    • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
    • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
    • Gently pry the digitizer connector up from its socket on the logic board.
  60. iPad Mini CDMA Logic Board Replacement: stap 60, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 60, afbeelding 2 van 2
    • Gently pry the digitizer cable board up from the rear case.
  61. iPad Mini CDMA Logic Board Replacement: stap 61, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 61, afbeelding 2 van 2
    • Lift and remove the front panel from the iPad.
  62. iPad Mini CDMA Logic Board Replacement, Battery: stap 62, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, Battery: stap 62, afbeelding 2 van 2
    • Reheat the iOpener in the microwave for one minute.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
    • Place the heated iOpener on the back of the iPad, along the center. Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the right of the back of the iPad (the side opposite the rear-facing camera), and let the iOpener sit for another 90 seconds.
    • If the iOpener cools significantly between sittings, reheat it for another minute.
  63. iPad Mini CDMA Logic Board Replacement: stap 63, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 63, afbeelding 2 van 2
    Plastic Cards
    $2.99
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Flip the iPad back over and insert a plastic card between the top left battery and the rear case.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
  64. iPad Mini CDMA Logic Board Replacement: stap 64, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 64, afbeelding 2 van 2
    • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
  65. iPad Mini CDMA Logic Board Replacement: stap 65, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 65, afbeelding 2 van 2
    • Remove the plastic card and reinsert it underneath the top right corner of the battery.
  66. iPad Mini CDMA Logic Board Replacement: stap 66, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 66, afbeelding 2 van 2
    • Again, press the card in further, to break more of the adhesive behind the battery.
    • Leave this card in place to prevent the adhesive from resetting.
  67. iPad Mini CDMA Logic Board Replacement: stap 67, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 67, afbeelding 2 van 2
    • Insert a second plastic card beneath the bottom left corner of the battery.
  68. iPad Mini CDMA Logic Board Replacement: stap 68, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 68, afbeelding 2 van 2
    • Slowly push the card in further, breaking more of the adhesive between the battery and the rear case.
  69. iPad Mini CDMA Logic Board Replacement: stap 69, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 69, afbeelding 2 van 2
    • Remove the card and reinsert it, beneath the bottom right corner of the battery.
  70. iPad Mini CDMA Logic Board Replacement: stap 70, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 70, afbeelding 2 van 2
    • Push the card further underneath the battery.
  71. iPad Mini CDMA Logic Board Replacement: stap 71, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 71, afbeelding 2 van 2
    • Grasp both cards and slowly pull the right side of the battery up about two inches from the rear case.
    • Peel slowly and try to keep the battery as straight as possible.
  72. iPad Mini CDMA Logic Board Replacement: stap 72, afbeelding 1 van 1
    • While lifting the right side of the battery up with one hand, use a plastic card to cut any adhesive still holding the battery down to the rear case.
  73. iPad Mini CDMA Logic Board Replacement: stap 73, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 73, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 73, afbeelding 3 van 3
    • Lift and remove the battery from the iPad.
  74. iPad Mini CDMA Logic Board Replacement, SIM Card Tray: stap 74, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, SIM Card Tray: stap 74, afbeelding 2 van 2
    • Use a SIM card eject tool or an uncoiled paperclip to eject the SIM card tray.
  75. iPad Mini CDMA Logic Board Replacement: stap 75, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 75, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 75, afbeelding 3 van 3
    • Use a fingernail to pull the SIM card tray out from the iPad.
    • Remove the SIM card tray.
  76. iPad Mini CDMA Logic Board Replacement, Small Metal Bracket: stap 76, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement, Small Metal Bracket: stap 76, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement, Small Metal Bracket: stap 76, afbeelding 3 van 3
    • Use the tip of a spudger to start peeling up the right side of the black tape covering the small metal bracket.
    • Use tweezers to peel the tape up the rest of the way, and remove it from the bracket.
  77. iPad Mini CDMA Logic Board Replacement: stap 77, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 77, afbeelding 2 van 2
    • Use a plastic opening tool to push the bracket slightly to the left.
  78. iPad Mini CDMA Logic Board Replacement: stap 78, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 78, afbeelding 2 van 2
    • Use a spudger tip to lift up the lower side of the bracket.
  79. iPad Mini CDMA Logic Board Replacement: stap 79, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 79, afbeelding 2 van 2
    • Remove the bracket with tweezers.
    • During reassembly, hook the top edge of the plate in place first, then lower the bottom into its slots.
  80. iPad Mini CDMA Logic Board Replacement, Logic Board Assembly: stap 80, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, Logic Board Assembly: stap 80, afbeelding 2 van 2
    • Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  81. iPad Mini CDMA Logic Board Replacement: stap 81, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 81, afbeelding 2 van 2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the upper metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  82. iPad Mini CDMA Logic Board Replacement: stap 82, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 82, afbeelding 2 van 2
    • Gently pry the second (lower) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  83. iPad Mini CDMA Logic Board Replacement: stap 83, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 83, afbeelding 2 van 2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  84. iPad Mini CDMA Logic Board Replacement: stap 84, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 84, afbeelding 2 van 2
    • Gently fold the front-facing camera cable up and out of the way of the logic board.
  85. iPad Mini CDMA Logic Board Replacement: stap 85, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 85, afbeelding 2 van 2
    • Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
  86. iPad Mini CDMA Logic Board Replacement: stap 86, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 86, afbeelding 2 van 2
    • Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
  87. iPad Mini CDMA Logic Board Replacement: stap 87, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 87, afbeelding 2 van 2
    • Pry the second (top) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the headphone jack cable connector.
  88. iPad Mini CDMA Logic Board Replacement: stap 88, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 88, afbeelding 2 van 2
    • Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
  89. iPad Mini CDMA Logic Board Replacement: stap 89, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 89, afbeelding 2 van 2
    • Gently bend the headphone jack cable back, away from the logic board.
  90. iPad Mini CDMA Logic Board Replacement: stap 90, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 90, afbeelding 2 van 2
    • Use a plastic opening tool to pry the top left antenna cable up from its socket on the logic board.
  91. iPad Mini CDMA Logic Board Replacement: stap 91, afbeelding 1 van 1
    • Remove the following three screws securing the top right antenna to the rear case:
    • Two 1.3 mm #00 Phillips screws from the side of the antenna's socket.
    • One 1.8 mm #00 Phillips screw.
  92. iPad Mini CDMA Logic Board Replacement: stap 92, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 92, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 92, afbeelding 3 van 3
    • Disconnect the top right antenna's coaxial cable from the logic board with a plastic opening tool.
    • Gently bend the cable and screw tab up out of the way of the logic board.
  93. iPad Mini CDMA Logic Board Replacement: stap 93, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 93, afbeelding 2 van 2
    • Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
  94. iPad Mini CDMA Logic Board Replacement: stap 94, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 94, afbeelding 2 van 2
    • Pry the top right antenna's ribbon cable up from its socket on the logic board with a plastic opening tool.
  95. iPad Mini CDMA Logic Board Replacement: stap 95, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 95, afbeelding 2 van 2
    • Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
  96. iPad Mini CDMA Logic Board Replacement: stap 96, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 96, afbeelding 2 van 2
    • Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
  97. iPad Mini CDMA Logic Board Replacement: stap 97, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 97, afbeelding 2 van 2
    • Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
  98. iPad Mini CDMA Logic Board Replacement: stap 98, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 98, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 98, afbeelding 3 van 3
    • Gently peel back the wide piece of tape covering the top of the right speaker.
  99. iPad Mini CDMA Logic Board Replacement: stap 99, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 99, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 99, afbeelding 3 van 3
    • Continue peeling the tape, and remove it from the iPad.
  100. iPad Mini CDMA Logic Board Replacement: stap 100, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 100, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 100, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
  101. iPad Mini CDMA Logic Board Replacement: stap 101, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 101, afbeelding 2 van 2
    • Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad.
    • Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
  102. iPad Mini CDMA Logic Board Replacement: stap 102, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 102, afbeelding 2 van 2
    • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
    • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
  103. iPad Mini CDMA Logic Board Replacement: stap 103, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 103, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 103, afbeelding 3 van 3
    • Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
  104. iPad Mini CDMA Logic Board Replacement: stap 104, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 104, afbeelding 2 van 2
    • De-route the antenna cable from the corner of the iPad.
  105. iPad Mini CDMA Logic Board Replacement: stap 105, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 105, afbeelding 2 van 2
    • Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
  106. iPad Mini CDMA Logic Board Replacement: stap 106, afbeelding 1 van 1
    • Peel the cable back from the corner of the iPad.
  107. iPad Mini CDMA Logic Board Replacement: stap 107, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 107, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 107, afbeelding 3 van 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  108. iPad Mini CDMA Logic Board Replacement: stap 108, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 108, afbeelding 2 van 2
    • Pull the antenna cable from the slot behind the Lightning connector.
  109. iPad Mini CDMA Logic Board Replacement, Plastic Covers: stap 109, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement, Plastic Covers: stap 109, afbeelding 2 van 2
    • Use tweezers to remove the small plastic cover on top of the horizontal screw on the right side of the Lightning connector housing.
  110. iPad Mini CDMA Logic Board Replacement: stap 110, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 110, afbeelding 2 van 2
    • Remove the plastic covering from the left side of the Lightning connector housing.
  111. iPad Mini CDMA Logic Board Replacement, Wi-Fi/Bluetooth Antenna: stap 111, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement, Wi-Fi/Bluetooth Antenna: stap 111, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement, Wi-Fi/Bluetooth Antenna: stap 111, afbeelding 3 van 3
    • Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
    • Slide the tip of a spudger through the gap between the wide tape and the antenna cable, breaking the adhesive connecting the two.
    • Continue pulling the wide tape until it is no longer covering the antenna cable.
  112. iPad Mini CDMA Logic Board Replacement: stap 112, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 112, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 112, afbeelding 3 van 3
    • Peel back and remove the wide tape from the iPad.
  113. iPad Mini CDMA Logic Board Replacement: stap 113, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 113, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 113, afbeelding 3 van 3
  114. iPad Mini CDMA Logic Board Replacement: stap 114, afbeelding 1 van 1
    • Remove the following three screws securing the bottom left antenna to the rear case:
    • One 1.2 mm Phillips #00 screw.
    • One 1.1 mm Phillips #00 screw.
    • One 2.5 mm Phillips #00 screw.
  115. iPad Mini CDMA Logic Board Replacement: stap 115, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 115, afbeelding 2 van 2
    • Use the flat end of a spudger to loosen the foam adhesive securing the lower left antenna to the left speaker.
  116. iPad Mini CDMA Logic Board Replacement: stap 116, afbeelding 1 van 1
    • Remove the antenna from the iPad.
  117. iPad Mini CDMA Logic Board Replacement, GPS Antenna: stap 117, afbeelding 1 van 1
    • Remove the following screws:
    • Two 1.1 mm Phillips #00
  118. iPad Mini CDMA Logic Board Replacement: stap 118, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 118, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 118, afbeelding 3 van 3
    • Use the flat end of a spudger to loosen the foam adhesive holding the antenna to the right speaker.
  119. iPad Mini CDMA Logic Board Replacement, Speakers: stap 119, afbeelding 1 van 1
    • Remove two 1.4 mm #00 Phillips screws securing the left and right speakers to the rear case.
  120. iPad Mini CDMA Logic Board Replacement: stap 120, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 120, afbeelding 2 van 2
    • Insert the tip of a spudger into the gap between the left speaker and the bottom left side of the rear case.
    • Pry around the bottom of the speaker, sliding it out from its recess in the rear case.
  121. iPad Mini CDMA Logic Board Replacement: stap 121, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 121, afbeelding 2 van 2
    • Once enough of the speaker is exposed, grasp it and pull it away from its recess in the rear case.
    • Remove the left speaker from the iPad.
  122. iPad Mini CDMA Logic Board Replacement: stap 122, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 122, afbeelding 2 van 2
    • Use the tip of a spudger to slide the right speaker slightly toward the outside of the iPad.
  123. iPad Mini CDMA Logic Board Replacement: stap 123, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 123, afbeelding 2 van 2
    • Insert the tip of a spudger into the gap between the right speaker and the bottom right corner of the case.
    • Pry the speaker out from its recess in the rear case.
  124. iPad Mini CDMA Logic Board Replacement: stap 124, afbeelding 1 van 2 iPad Mini CDMA Logic Board Replacement: stap 124, afbeelding 2 van 2
    • Once enough of the speaker is exposed, grasp it and pull it away from its slot in the rear case.
    • Remove the right speaker from the iPad.
  125. iPad Mini CDMA Logic Board Replacement: stap 125, afbeelding 1 van 1
    • Remove two 2.8 mm Phillips #00 screws from the base of the Lightning connector.
  126. iPad Mini CDMA Logic Board Replacement, Logic Board: stap 126, afbeelding 1 van 1
    • Place the heated iOpener on the left side of the back of the iPad. Let it sit there for 90 seconds to soften the logic board adhesive.
  127. iPad Mini CDMA Logic Board Replacement: stap 127, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 127, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 127, afbeelding 3 van 3
    • Slide the flat end of a spudger underneath the Lightning port cable, freeing it from the adhesive securing it to the rear case.
  128. iPad Mini CDMA Logic Board Replacement: stap 128, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 128, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 128, afbeelding 3 van 3
    • Gently insert the flat end of a spudger underneath the logic board at various points, slowly prying it up from the rear case.
    • Be very careful to pry evenly and avoid bending or stressing the logic board. If it is hard to insert the spudger, reheat the iOpener and reapply it to the back of the iPad.
  129. iPad Mini CDMA Logic Board Replacement: stap 129, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 129, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 129, afbeelding 3 van 3
    • Continue to use the spudger to pry the logic board up from the rear case.
  130. iPad Mini CDMA Logic Board Replacement: stap 130, afbeelding 1 van 3 iPad Mini CDMA Logic Board Replacement: stap 130, afbeelding 2 van 3 iPad Mini CDMA Logic Board Replacement: stap 130, afbeelding 3 van 3
    • Once all of the adhesive is broken and the logic board is free, gently lift it up from the top.
    • Again, be careful not to bend or stress the logic board—make certain that you have cleared all of the adhesive with the spudger.
    • Lift the logic board and Lightning cable assembly up and pull toward the top of the iPad to remove the Lightning connector from its housing.
    • Remove the assembly from the iPad.
Conclusie
11 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
This was supposed to be a logic board guide not everything in one
l g - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 77
Altijd: 29,079
