Ga door naar hoofdinhoud
iPad Mini 2 Wi-Fi Front Panel Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 2 iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  2. iPad Mini 2 Wi-Fi Front Panel Replacement: stap 2, afbeelding 1 van 3 iPad Mini 2 Wi-Fi Front Panel Replacement: stap 2, afbeelding 2 van 3 iPad Mini 2 Wi-Fi Front Panel Replacement: stap 2, afbeelding 3 van 3
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  3. iPad Mini 2 Wi-Fi Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Lift and remove the front panel from the iPad.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sam Goldheart
471.886 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.649 handleidingen geschreven
2Gids Commentaar
I'll give this quide a 3/5. The problem is the end where you just say reverse the steps. That is an easy out that too many people use. There are important things to do when re-assembling that are not pointed out that may come back to bite you just attempting to reverse the steps. I do like the stepped pictures showing before and after views. Overall the process is not that bad other than removing the broken glass which breaks a lot more as you go. A hair dryer on high worked fine for warming up the glue, you just need to be aware of cleaning the area of glass bits before turning it on. Glad I didn't pay somebody big bucks to do this job.
italternatives - Antwoord
Due reassebling its really important to bend the digitizer cable with a spudger inside the case. If you just press the Front down the cable will be between adhensive and case. So near the home button, it won't fit very well!!
itf7o - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 6,555
