Inleiding
This guide shows how to apply display assembly adhesive to an opened iPad.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue.
Use tweezers to pull up sections of tape residue.
Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive.
Remove the residue by wiping in one direction to prevent smearing.
Lay out the replacement adhesive strips around the display assembly so that they correspond to the correct sides.
Beim iPad Air müssen die Klebestreifen übrigens nicht auf das Gehäuse, sondern an das Front Panel geklebt werden.
Danke. Sehr gut.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
40 andere personen hebben deze handleiding voltooid.
8 Opmerkingen
Thanks, I was able to fix my wife’s shattered digitizer screen on the iPad 6th gen with this guide!
I managed to get it done, but this was a personal nightmare for me and more difficult than replacing the battery in my ipad. There are too many instruction that say “remove plastic” and I have no idea which layer; there was nothing on the packaging to indicate which side was up or which side was the front and I ended up guessing the wrong direction because it “looked” right, but wasn’t. A simple sticker on the packaging indicating a direction would have removed all of the frustration. I only managed to figure it out by removing all of the plastic so that the sticky side of the adhesive was exposed and then I could finally see how it was supposed to fit and how I was supposed to press down with the other side of the plastic to push the adhesive side into the frame.
Fixed a cracked iPad 4 mini screen; I agree with twizzlercraze72. Some kind of labeling would have saved so much peeling and re-sticking. I ended up with a gap next to my home button. An expensive lesson to learn.
For me, actually replacing the battery wasn’t too bad, but I ended up using too much isopropyl to clean off the old glue, and it seeped under the display and ruined it. Wish Apple didn’t use so much glue. It massively impedes repairability, which is not very environmentally sound. My iPad was perfect apart from the battery - it’s now got a perfect battery but the iPad is ruined :-(
Same here :(. $50 repair just turned into $250!
Adhesive: Used CRC Brakleen PRO SERIES. Applied sparingly with a Q-tip 2 inches at a time. Softened the adhesive was easily squeezed off with a plastic spudger. Final cleaned with Isopropyl.
Application: Went as instructed including sick book method over night.
Result: Display is secure except on the upper left side ½” below the corner. This is the area where the adhesive narrows for about an inch. The narrowing is not necessary on an iPad Air 2. In hind site adding some Tesa 61395 Tape in the narrowed areas would have prevented reopening to redo the adhesive. At this point using B7000 adhesive may have been a better choice.
AT LEAST THIS recognizes that taping the screen back in place is a non-trivial task. I have searched through multiple iPad ifixit repairs and they all say "Now that you have got it apart now just do the reverse with the good part".
FI's
Interesting the the tape is applied prior to reconnecting the digitizer
I followed these instructions and used 99.9% isopropyl alcohol to clean off the glue around the display - but the isopropyl leaked under the screen and ruined it! Replacement screen more than the iPad’s worth. Use tiny amounts and don’t allow for any seepage, or try to manage without and just carefully scape. My iPad’s now a write-off… :-(
Alex Harness - Antwoord
Hi Alex!
I’m really sorry to hear about your experience. Can you describe a little more how the alcohol ruined the screen? This info can help with future guides!
Arthur Shi -
Use goof off or xylene on cotton swab outdoors to remove adhesive. Do it outside so you don’t smell up the house. Better than rubbing alcohol.
macman2 - Antwoord
Goof-off will unfortunately leave a residue that can eventually weaken the replacement adhesive. Be sure to fully clean off the surface with alcohol after you use Goof-off.
Arthur Shi -
I used a hair dryer to soften the adhesive.
OK, you still leave a very small, microscopic, layer of adhesive after removing the black tape, but really, new tape will still stick to that. We’re not trying to make the iPad water proof - we’re simply trying to make the components secure and not fall apart. Shame Apple couldn’t have used screws instead!
Billinski - Antwoord
dklj - Antwoord
