Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Gereedschappen die in deze demontage worden gebruikt
Inleiding
This is the teardown for a Clamcase for iPad 2.
Deze demontage is geen reparatiehandleiding. Om je iPad ClamCase te repareren, gebruik onze reparatiehandleidingen.
  1. You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other. Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
  2. Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side. Use  the T6 Torx screwdriver to unscrew the remaining 4 screws.
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
  3. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Turn the keyboard cover over so the bottom is facing up.  Manually remove the thin black covering that is attached to the bottom. Be patient, the thin black covering might be really stuck to the bottom.
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
  5. Once the thin black covering is removed, you will see 15 screws.
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
  6. Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  7. You are done.
    • You are done.
Izmet Barranco
213 Reputatie
1 Handleiding geschreven
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Antwoord
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 6,853
