Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
prereq for everything upper case
  1. Remove the following screws securing the upper component cable bracket:
    • Remove the following screws securing the upper component cable bracket:
    • Two 2.0 mm Phillips screws
    • Three 1.4 mm Phillips screws
  2. Use tweezers to start peeling back the tape securing the upper component cable bracket. Use tweezers to start peeling back the tape securing the upper component cable bracket.
    • Use tweezers to start peeling back the tape securing the upper component cable bracket.
  3. Slowly peel the upper component cable bracket up out of the iPad—leaving the tape pieces on the bracket to make it easier to reinstall. Slowly peel the upper component cable bracket up out of the iPad—leaving the tape pieces on the bracket to make it easier to reinstall. Slowly peel the upper component cable bracket up out of the iPad—leaving the tape pieces on the bracket to make it easier to reinstall.
    • Slowly peel the upper component cable bracket up out of the iPad—leaving the tape pieces on the bracket to make it easier to reinstall.
Conclusie
Andrew Optimus Goldheart
468.502 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
134 Leden
14.939 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 51
