Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Remove the front panel assembly from an iPad Air 2 to access any internal component for repair or replacement.
Warning: the battery isolation method in this guide is outdated, and may result in irreversible damage to the battery pins of the logic board, effectively destroying it. If you choose to isolate the battery this way, heed all warnings and work extremely carefully. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Wat je nodig hebt
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Per separare il display con i plettri avete descritto 18 passaggi, ok, così anche i bambini capiscono.
Per isolare la batteria, cosa molta importante, avete descritto solo 2 passaggi in modo poco chiaro: non si capisce se il plettro è un plettro predisposto, se bisogna tagliarne uno e come si infila al di sotto del connettore senza fare danni.
Buongiorno!
Abbiamo un plettro predisposto: Battery Blocker
Poi grazie per l’osservazione! Hai ragione, le spiegazioni per isolare la batterie non erano esaustive, perciò la guida originale in inglese è stata adattata. La traduzione non era più attuale. L’abbiamo aggiornata. Nostro sito è un wiki che viene migliorato e completato continuamente. Così anche gli utenti hanno la possibilità di modificare direttamente le guide e di aiutarci a tradurle.
Buona riparazione!
