Ga door naar hoofdinhoud
iPad 7 Glass Digitizer Replacement
Wat je nodig hebt
  1. iPad 7 Glass Digitizer Replacement, Glass Digitizer: stap 1, afbeelding 1 van 1
    • Apply heat to the screen(along the red lines), my personal rule is that hot to the touch is the best level of heat in order to weaken the adhesive. (Although not too hot).
    • I prefer to use a heating pad to heat the screen enough in order to weaken the adhesive. You may also use a hair dryer and focus the heat onto the edges of the device in order to weaken the adhesive.
  2. iPad 7 Glass Digitizer Replacement: stap 2, afbeelding 1 van 3 iPad 7 Glass Digitizer Replacement: stap 2, afbeelding 2 van 3 iPad 7 Glass Digitizer Replacement: stap 2, afbeelding 3 van 3
    • Pry around the screen's edges as shown. Be careful of parts at the bottom, and under the screen, such as the home button, Wifi attachments, and GPS antennas.
    • The screen is connected by a ribbon cable about 1/3 of the way up the right edge. Take particular care at that point.
    • Depending on the nature of the crack in the screen it is likely that the screen will form glass shards. Be careful with your hands and wear gloves if possible.
  3. iPad 7 Glass Digitizer Replacement: stap 3, afbeelding 1 van 1
    • Lift and jiggle the digitizer from the top left.
    • The screen will swing open like a hinge on the ribbon cable on the right side of the screen.
  4. iPad 7 Glass Digitizer Replacement: stap 4, afbeelding 1 van 3 iPad 7 Glass Digitizer Replacement: stap 4, afbeelding 2 van 3 iPad 7 Glass Digitizer Replacement: stap 4, afbeelding 3 van 3
    • Prop-up the glass digitizer in order to have both hands free.
    • Unscrew the 4 PH000 screws from the four corners of the LCD screen.
    • Use a metal tool to gently pry up the LCD from the top left and right screw brackets.
  5. iPad 7 Glass Digitizer Replacement, Lift out the LCD: stap 5, afbeelding 1 van 1
    • Lift the LCD screen from the top carefully.
  6. iPad 7 Glass Digitizer Replacement: stap 6, afbeelding 1 van 2 iPad 7 Glass Digitizer Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the 1 PH000 screw from the battery connection.
    • Slide a plastic pick under the battery connection.
    • Unscrew the 3 PH000 screws from the display cable bracket.
  7. iPad 7 Glass Digitizer Replacement: stap 7, afbeelding 1 van 3 iPad 7 Glass Digitizer Replacement: stap 7, afbeelding 2 van 3 iPad 7 Glass Digitizer Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the LCD ribbon cable.
    • Disconnect the digitizer's two ribbon cable connections.
    • Swing open the lock which holds the home button ribbon cable in place.
    • Disconnect the home button ribbon cable with the flat end of a plastic spudger, or gently slide it out of the connection port with tweezers.
  8. iPad 7 Glass Digitizer Replacement: stap 8, afbeelding 1 van 1
    • Remove the cable from the iPad housing and keep the rubber covering over the home button cable.
    • It is now safe to remove the glass digitizer fully from the iPad housing.
  9. iPad 7 Glass Digitizer Replacement, Pry the home button out: stap 9, afbeelding 1 van 3 iPad 7 Glass Digitizer Replacement, Pry the home button out: stap 9, afbeelding 2 van 3 iPad 7 Glass Digitizer Replacement, Pry the home button out: stap 9, afbeelding 3 van 3
    • Use a heat gun or heating pad to heat up the home button for removal. A blow dryer may also work.
    • Lift the home button upwards pulling gently on the ribbon cable. Be careful to not damage the cable.
    • Gently pry off the metal home button bracket with a metal pry tool.
  10. iPad 7 Glass Digitizer Replacement, Add liquid adhesive: stap 10, afbeelding 1 van 3 iPad 7 Glass Digitizer Replacement, Add liquid adhesive: stap 10, afbeelding 2 van 3 iPad 7 Glass Digitizer Replacement, Add liquid adhesive: stap 10, afbeelding 3 van 3
    • With the home button and bracket removed, apply liquid adhesive around the new glass digitizer's home buttonhole.
  11. iPad 7 Glass Digitizer Replacement: stap 11, afbeelding 1 van 3 iPad 7 Glass Digitizer Replacement: stap 11, afbeelding 2 van 3 iPad 7 Glass Digitizer Replacement: stap 11, afbeelding 3 van 3
    • Place the home button down first, then place the metal bracket. Give the button some test clicks to insure it is mounted correctly and stable.
    • Prepare for testing, by reconnecting the home button and glass digitizer's ribbon cables in the same way they were disconnected in step 7.
    • Remove the plastic pick from the battery connector and replace the PH000 screw.
    • Replace the display cable bracket with its 3 PH000 screws.
    • Make sure you clean the edges before continuing. A Q-Tip with a very small amount of isopropanol can assist in this. Any debris in the digitizer groove can cause the digitizer to crack.
    • Remount the LCD using its 4 PH000 screws into the iPad housing.
  12. iPad 7 Glass Digitizer Replacement: stap 12, afbeelding 1 van 1
    • Lay the new digitizer into its groove.
    • Do not glue until the new digitizer and home button have been tested.
    • Power on the iPad and verify the device is working properly.
    • Lift the digitizer back up gently, ensure the LCD and inside pane of the digitizer are clean.
    • Run a small bead of glue along the edge of the digitizer groove on the iPad housing.
    • Relay the digitizer into its groove and gently clamp until the glue sets.
Conclusie
The replaced screen should function identically to the original prior to the damage.
15 andere personen hebben deze handleiding voltooid.
Mark D Schlossman
5.537 Reputatie
8 handleidingen geschreven
Één opmerking
Great guide! This applies to the iPad 8 identically.
Benjamin Klenklen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 128
Afgelopen 30 dagen: 670
Altijd: 18,402
