Inleiding
Use this guide to replace adhesive strips and re-seal your iPad 4 after a repair.
Only for use with EXISTING front panel assemblies.
Gereedschap
Onderdelen
Remove the two 2.1 mm Phillips #00 Phillips screws securing the home button control board to the home button mounting bracket.
In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
Do not peel the clear backing off the strips just yet.
Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
8 andere personen hebben deze handleiding voltooid.
