Inleiding
Use this guide to replace the Wi-Fi Antenna.
Gereedschap
Onderdelen
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
Use the flat end of a spudger to pry the dock connector cable straight up out of its socket on the logic board.
Peel up the dock connector cable from the aluminum frame.
Use the tip of a spudger to pry the speaker and Wi-Fi antenna connectors straight up off their sockets on the logic board.
36 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
I need some help please : I just put back the digitalizer, I did each step very carefully and I have verified LCD and digitalizers ribbons before to put them back, but now the LCD screen doesn't switch on... When I plug the iPad on my PC, iTunes works normally and detects everything in the pad, and when I plug it I can hear all its sounds... do you think that the LCD screen is dead? How can I verify it please? Thanks for your help.
Help!
I snipped off the final 5mm of my iPad3 wifi aerial by mistake when I replaced the screen the other day. As a result the wifi range is significantly diminished. Replacing the whole aerial looks pretty daunting. Does anyone know if I can just replace the end of the aerial or extend it all?
Has anyone a similar experience?
Thanks
Pete
