Inleiding
Replace the adhesive securing the front panel to the rear case of your iPad 2 Wi-Fi.
Before you begin peeling and sticking tape, it's important to have clean adhesion surfaces on both the front panel and the rear case. Use a spudger to scrape off any large excess bits of original adhesive, then clean all of the gluing surfaces with a paper towel and rubbing alcohol or Goof Off.
Throughout this procedure, it is recommended to peel up each adhesive strip as needed.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Carefully grasp the home button with a pair of tweezers.
Gently lower and place the home button into the round opening located at the bottom of the front panel.
128 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I think a straight on picture showing all the adhesive pieces in place would be really helpful.
How am i supposed to put the digitizer cable back, and how do i put the fron on it?
