Ga door naar hoofdinhoud
Inleiding
Internal guide for removing LCD before logic board.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Carefully lay the LCD next to the rear panel. Use a plastic opening tool to lift the display data cable lock upwards. Pull the display data cable out of its socket.
    • Carefully lay the LCD next to the rear panel.
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Do not pull the connector upward as you disconnect it from its socket.
  2. Remove the LCD assembly from the rear panel assembly.
    • Remove the LCD assembly from the rear panel assembly.
Conclusie
Andrew Optimus Goldheart
483.646 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
146 Leden
17.089 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 159
