Ga door naar hoofdinhoud
iNNEXT N64 Classic Controller Shoulder Buttons Replacement
  1. iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Bottom Case: stap 1, afbeelding 1 van 2 iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
  2. iNNEXT N64 Classic Controller Shoulder Buttons Replacement: stap 2, afbeelding 1 van 1
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
  3. iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Shoulder Buttons: stap 3, afbeelding 1 van 2 iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Shoulder Buttons: stap 3, afbeelding 2 van 2
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
Eindstreep
Khaymare commock
265 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 3-4, Santin Fall 2024 Lid van UMass Dartmouth, Team 3-4, Santin Fall 2024
UMASSD-SANTIN-F24S3G4
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 125
