Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew the case and take the 56x35 whiteboard, check that it fits nicely.
Apply contact cement to the inside borders of the front case. Leave to dry for about 5 minutes.
Place the whiteboard onto the front case and put weight on it.
Make sure that the whiteboard touches the lower side of the metal panel.
Leave to dry out for a day.
Mark up 4 lines of 4cm each on the cardboard.
Cut up a rectangle and fold to make up a cylinder. Use scotch tape to hold them together.
Repeat to get 2 more cylinders.
Glue the cylinders to the back case of the iMac.
This is to have some pressure against the whiteboard.
After the contact cement has dried, take out the small contact cement remnants from the board with a box cutter and a plastic tool (as to not damage the whiteboard)
4 opmerkingen
Great idea! How about adding an attachment to the bottom of the stand to hold a book open. Maybe use the speaker case cut to size. Affix it using the holes for the RAM access plate.
Thats a great idea too! If you add the stand post some pics ^_^
Angela, I tried contacting you via twitter, would you click on my icon and email me. This is about my possible relocation to Ecuador .
Done! Check your inbox :)
