Inleiding
Use this guide to remove or replace the AirPort/Bluetooth card in your iMac Intel 27" Retina 5K Display.
Gereedschap
Onderdelen
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
To reassemble your device, follow these instructions in reverse and use our adhesive strip replacement guide to reattach the display glass.
