Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
prerequisite for logic board, heat sink, and CPU
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the four 7.5 mm T8 screws from behind the GPU on the logic board. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
    • Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
    • These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
  2. Remove the bracket from behind the GPU heat sink.
    • Remove the bracket from behind the GPU heat sink.
  3. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  4. Remove four black stickers from the back of the CPU heat sink.
    • Remove four black stickers from the back of the CPU heat sink.
  5. Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
    • Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
  6. Remove the spring plate from behind the CPU heat sink. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
    • Remove the spring plate from behind the CPU heat sink.
    • Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
  7. Lift the heat sink up from the logic board. The CPU will most likely stick to the heat sink, so be careful about where you put it down. The CPU will most likely stick to the heat sink, so be careful about where you put it down.
    • Lift the heat sink up from the logic board.
    • The CPU will most likely stick to the heat sink, so be careful about where you put it down.
Conclusie
Andrew Optimus Goldheart
461.945 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
131 Leden
13.426 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 149
