Inleiding
This is a guide on how to upgrade your Mid 2011 iMac's Ram, HDD, CPU, and GPU. This guide also shows you how to clean out the fans of your iMac.
Wat je nodig hebt
First Start by unplugging all cables from your iMac and setting up a workstation.
Gereedschap gebruikt in deze stap:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
Where is the rest of this guide?
Obviously not following this guide, I opened my iMac that had full graphics failure, uninstalled the GPU-card, cleaned it, baked it in the oven to soften the solder and let the chip reattach itself, added new conductive paste, reinstalled it and it worked again.
I can't remember the temperatures, but there are tutorials to be found.
Non è una guida. Manca tutto!
