Ga door naar hoofdinhoud
iMac Intel 27" EMC 2429 AirPort Card Replacement
Wat je nodig hebt
    1. iMac Intel 27" EMC 2429 AirPort Card Replacement, Glass Panel: stap 1, afbeelding 1 van 3 iMac Intel 27" EMC 2429 AirPort Card Replacement, Glass Panel: stap 1, afbeelding 2 van 3 iMac Intel 27" EMC 2429 AirPort Card Replacement, Glass Panel: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Heavy-Duty Suction Cups (Pair)
      $16.95
      • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
      • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
      • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
      • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
      • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
      • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
      Vraag FixBot
      Voeg opmerking toe
    2. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 2, afbeelding 1 van 3 iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 2, afbeelding 2 van 3 iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 2, afbeelding 3 van 3
      • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
      • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
      • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
      • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
      • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
      Vraag FixBot
      Voeg opmerking toe
    1. iMac Intel 27" EMC 2429 AirPort Card Replacement, Display: stap 3, afbeelding 1 van 1
      • Remove the eight T10 Torx screws securing the LCD to the outer case.
      • Be careful not to touch the display as the oil from your fingers may leave a residue that can be difficult to remove.
      • If necessary, peel the EMI gaskets located near the top center edge of the display assembly.
      Vraag FixBot
      Voeg opmerking toe
    2. iMac Intel 27" EMC 2429 AirPort Card Replacement, Display: stap 4, afbeelding 1 van 3 iMac Intel 27" EMC 2429 AirPort Card Replacement, Display: stap 4, afbeelding 2 van 3 iMac Intel 27" EMC 2429 AirPort Card Replacement, Display: stap 4, afbeelding 3 van 3
      $3.99
      • Carefully lay the iMac stand-side down on a flat surface.
      • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the first picture, we made one out of a bent paperclip. A pair of angled tweezers can also work well.
      • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
      • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
      • Raise and hold the display high enough to access the cables.
      • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
      Vraag FixBot
      Voeg opmerking toe
    3. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 5, afbeelding 1 van 1
      • Disconnect the vertical sync cable in the upper left corner of the screen. Use the tip of a spudger to push on the connector's side tabs and gently walk it out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    4. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 6, afbeelding 1 van 1
      • This step brings your hands close to the exposed rear of the power supply. To avoid a high-voltage shock from the many large capacitors attached to the board, do NOT touch the rear of the power supply.
      • Disconnect the LED backlight driver cable with your hand by pressing the tab down and sliding it towards the bottom of the display.
      Vraag FixBot
      Voeg opmerking toe
    5. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 7, afbeelding 1 van 2 iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 7, afbeelding 2 van 2
      • Pull the black tab straight up to disconnect the latch on the display data cable ZIF connector.
      • Do not pull up too hard or you will damage the connector and socket.
      • Continue to pull the black tab up toward the top of the device, to detach the display data cable.
      Vraag FixBot
      Voeg opmerking toe
    6. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 8, afbeelding 1 van 1
      • Use the tip of a spudger to disconnect the display power cable next to the display data cable.
      Vraag FixBot
      Voeg opmerking toe
    7. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 9, afbeelding 1 van 1
      • Carefully pull the display toward the top edge of your iMac and lift it out of the iMac case.
      Vraag FixBot
      Voeg opmerking toe
    8. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 10, afbeelding 1 van 1
      • Lay the display face down on a flat, soft surface.
      • If you are replacing the display panel, you will need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
      • If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
      • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
      • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
      Vraag FixBot
      Voeg opmerking toe
    1. iMac Intel 27" EMC 2429 AirPort Card Replacement, AirPort Card: stap 11, afbeelding 1 van 2 iMac Intel 27" EMC 2429 AirPort Card Replacement, AirPort Card: stap 11, afbeelding 2 van 2
      • Locate the AirPort card at the top center of the logic board and just below the hard drive.
      • Use the flat end of a spudger to gently pry each of the antenna cables off their sockets.
      • Do not disconnect the antennas by pulling on the cables as this may damage the cables, connectors, or sockets.
      • The antennas have markings to help you identify their order. The antenna with no marks goes to "CH0", the antenna with one mark goes to "CH1", and the antenna with two marks goes to "CH2".
      Vraag FixBot
      Voeg opmerking toe
    2. iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 12, afbeelding 1 van 2 iMac Intel 27" EMC 2429 AirPort Card Replacement: stap 12, afbeelding 2 van 2
      • Remove the T6 Torx screw securing the AirPort card to the logic board frame.
      • The card will begin to tilt away from the iMac case as you remove the screw. Its final resting angle should be the angle at which it is removed and reinstalled.
      • Remove the AirPort card by pulling it straight out of its socket.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Phillip Takahashi
87.976 Reputatie
87 handleidingen geschreven
7Gids Commentaar
I have a question, and I hope that this is the right place to ask. Can I replace the original Airport card with a BROADCOM BCM94360CD and a minicpi adaptor and get 802.11AC and Bluetooth 4.0? I know the BCM94360CD has four antenna connectors and the original Airport card only has three. Any guidance there? The connectors on the BCM94360CD are labeled "J0", "J1", "J2" and "J3". Thanks in advance!
gshields - Antwoord Deel
Google osxwifi. The extra connector is Bluetooth. 2011 it was 2 separate cards, the newer models are combo Bluetooth + wifi AC cards. Because of this, The pci adapter needs the USB pins, and an extension cable for the BT antenna to work with 2011 models. I've done that mod to my mid 2011 27" iMac.
joer293 - Antwoord Deel
This may sound silly but I am installing the Broadcom Bcm94360cd so I can have hand off in my mid 2011 27" iMac. I was wondering where does the USB cable get plugged in? Also do I have to remove the actual Bluetooth card since it's a separate piece in order for this to work? Please help. Thank You.
bmdowney901 - Antwoord Deel
I am also installing the upgrade kit. Do you already know where does the usb cable get plugged in and if it is necessary to remove Bluetooth card? Thank you!
André Senra - Antwoord Deel
Hello, bravo for this tutorial.
On an Imac 2011 27 ', what are the three antennas connected to the Airport card?
The CH1 connector is broken. This corresponds to the large antenna fixed to the back of the Imac. Thank you for your reply.
Maillard - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 123
Altijd: 46,721
