Inleiding
Use this guide to replace a faulty SD Board.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
4 andere personen hebben deze handleiding voltooid.
Één commentaar
One must consider, the USP based card adapter is like five dollars.
When I tell customers this, they usually get that instead of paying me $100 plus parts to repair it
