Inleiding
Backlight not working? Use this guide to replace a broken LED driver board.
Onderdelen
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Remove the four T10 Torx screws securing the LED driver board to the outer case.
10 andere personen hebben deze handleiding voltooid.
