Ga door naar hoofdinhoud
iMac Intel 27" EMC 2390 Access Door Replacement
Wat je nodig hebt
  1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: stap 1, afbeelding 1 van 2 iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: stap 1, afbeelding 2 van 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Één opmerking
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
Kevin McCartney - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 32
Altijd: 9,347
