Inleiding
Remove the access door to replace RAM modules.
Wat je nodig hebt
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
12 andere personen hebben deze handleiding voltooid.
Één opmerking
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
