Inleiding
iMac Intel 24" EMC 2267 CPU replacement
Wat je nodig hebt
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Gereedschap gebruikt in deze stap:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Remove the two 5.3 mm T6 torx screws from the LCD connector.
Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
Start by following the excellent guide from Jeff Dickson from step 2 to step 9
Remove the four Philips #2 screws.
Flip over the logic board.
Unscrew and remove the four Torx 8 screws.
Wipe the thermal paste with with a microfibre cloth wetted with an alcoholic solution.
Rotate the locking screw by half a turn (counterclockwise).
Gently remove the old CPU lifting it up vertically.
Align the socket and the new CPU with the help of the trimmed corner.
Gently drop the CPU in its socket.
Lock the CPU by rotating the locking screw half a turn clockwise.
Drop a little bit of thermal paste on the center of the CPU.
To reassemble your device, follow the instructions in reverse order.
7 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Één opmerking
Anyone have any tips or advice as to what CPUs would work best?
