Ga door naar hoofdinhoud
iMac Intel 24" EMC 2134 and 2211 RAM Replacement
Wat je nodig hebt
  1. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, Access Door: stap 1, afbeelding 1 van 1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: stap 2, afbeelding 1 van 2 iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: stap 2, afbeelding 2 van 2
    • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM module.
  3. iMac Intel 24" EMC 2134 and 2211 RAM Replacement: stap 3, afbeelding 1 van 1
    • Grab the RAM module by its edges and pull it straight out of its slot.
    • If two RAM modules are installed, repeat this process for the other chip.
Conclusie
53 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
90.418 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.608 handleidingen geschreven
5Gids Commentaar
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
Edouard Gilbert - Antwoord
EMC2134 requires PC2-5300 as specified here. PH1 worked ok. Need to give RAM tabs a pretty firm pull to initially unseat, then it is easy to slide RAM back.
lcgillies - Antwoord
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
ericgossick - Antwoord
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
davidfoster11 - Antwoord
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
Alistair Prewett - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 97
Altijd: 40,151
