Ga door naar hoofdinhoud
iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement, Display Panel: stap 1, afbeelding 1 van 2 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement, Display Panel: stap 1, afbeelding 2 van 2
    • Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
    • If necessary, de-route the LCD temperature sensor cable from behind the logic board.
  2. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5.3 mm T6 Torx screws securing the display data cable to the logic board.
  3. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the display data cable connector from its socket on the logic board by pulling the attached plastic tab towards you and away from the iMac.
  4. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 4, afbeelding 1 van 2 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 4, afbeelding 2 van 2
    • Lay the iMac down on a table before you remove the LCD so that it doesn't fall.
    • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
    • Lift the right side of the display panel a few inches up from the iMac.
    • Do not lift the LCD all the way up; there are still connectors attaching the LCD to the internals.
  5. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 5, afbeelding 1 van 2 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 5, afbeelding 2 van 2
    • With the LCD lifted, disconnect the LCD cable by pulling down.
    • The LCD cable is attached to the underside of the power supply; be careful where you put your fingers so you don't get zapped by a capacitor.
    • On reassembly, you may find it helpful to remove the power supply, reconnect the LCD power cable, and then reinstall the power supply.
    • Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
  6. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 6, afbeelding 1 van 2 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: stap 6, afbeelding 2 van 2
    • Continue to lift the LCD from the right side.
    • Remove the LCD.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.739 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 2,949
