Inleiding
Use this guide to replace a broken optical drive.
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Remove the two T6 Torx screws securing the optical drive cable to the optical drive.
Use the flat end of a spudger to remove the pieces of EMI foam from the underside of the optical drive.
7 andere personen hebben deze handleiding voltooid.
