Inleiding
Use this guide to replace or upgrade your hard drive.
Gereedschap
Onderdelen
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Remove the following screws securing the hard drive bracket to the rear enclosure:
Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
One 9 mm T10 Torx screw.
One 27 mm T10 Torx screw.
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
Peel the rubber hard drive bumpers up off the top and bottom edges of the hard drive.
260 andere personen hebben deze handleiding voltooid.
38 Opmerkingen
Super awesome instructions, As always easy to follow, swapped out he drive pretty quick. makes me miss the magnets for sure.
Great instructions, I chose to purchase the adhesive strips from Ifixit and they worked great, much easier than trying to shape your own plus they stick really well.
Great instructions. Is it possible to replace HD with a SSD Samsung EVO ?
thanks
