Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace the left speaker.
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  1. Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Be gentle! The glass may crack if pried too much. Use a hairdryer to heat the edges and loosen the tape if the room temperatures are low.
  2. Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  3. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner.
    • Continue running the tool up around the top left corner.
  4. Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
    • Cut the adhesive along the top left of the display.
  5. Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  6. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
    • Push the tool around the top right corner of the display.
  7. Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
    • Wheel the tool down along the right side of the display.
  8. Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  9. While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  10. Gently twist the plastic card sideways to create a gap between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  11. Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac. Be sure to stop before the iSight camera, or you may damage it. Be sure to stop before the iSight camera, or you may damage it.
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  12. Wedge the plastic card into the top right corner once again and let it stay there to keep the adhesive from resettling. Wedge the plastic card into the top right corner once again and let it stay there to keep the adhesive from resettling.
    • Wedge the plastic card into the top right corner once again and let it stay there to keep the adhesive from resettling.
  13. Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac.
    • Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac.
  14. Gently twist the card upward, slightly increasing the space between the display and frame. As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  15. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  16. Wedge the plastic card back into the top left corner. Wedge the plastic card back into the top left corner.
    • Wedge the plastic card back into the top left corner.
  17. With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  18. While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires. Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  19. Use the tip of a spudger to flip up the metal retaining bracket on the display data cable. Carefully pull the display data cable from its socket on the logic board. Be sure to pull the display data cable connector straight out of its socket.
    • Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
  20. Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  21. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  22. Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • During reassembly, head over to our display adhesive guide to install the new adhesive.
  23. Remove the following five Phillips  screws holding the lower support bracket in place: Four 3.2 mm screws
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • On at least some EMC 2544 machines, all five screws are the same size.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  24. Remove the lower support bracket from the iMac enclosure.
    • Remove the lower support bracket from the iMac enclosure.
  25. Disconnect the fan cable connector from its socket on the logic board. Disconnect the fan cable connector from its socket on the logic board.
    • Disconnect the fan cable connector from its socket on the logic board.
  26. Remove the three 12.3 mm T10 shoulder screws from the fan enclosure.
    • Remove the three 12.3 mm T10 shoulder screws from the fan enclosure.
  27. Remove the fan from the iMac. Remove the fan from the iMac.
    • Remove the fan from the iMac.
  28. Gently pull the left speaker cable straight out of its socket on the logic board. Gently pull the left speaker cable straight out of its socket on the logic board.
    • Gently pull the left speaker cable straight out of its socket on the logic board.
  29. De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  30. Use a spudger to disconnect the power button connector from its socket on the logic board. Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock. Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
    • Use a spudger to disconnect the power button connector from its socket on the logic board.
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
  31. Remove the two 10.0 mm T10 screws securing the left speaker to the rear case.
    • Remove the two 10.0 mm T10 screws securing the left speaker to the rear case.
    • Rubber washers keep the screws snug in the speaker even when loosened. You can use tweezers or a fingernail to remove the screws, or simply leave them with the speaker assembly.
  32. Lift the left speaker straight up, until the power button cable is exposed (about 0.5"). Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
    • Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
  33. Gently de-route the power button cable from its groove in the left speaker. Gently de-route the power button cable from its groove in the left speaker. Gently de-route the power button cable from its groove in the left speaker.
    • Gently de-route the power button cable from its groove in the left speaker.
  34. Lift the left speaker straight up and remove it from the iMac. Lift the left speaker straight up and remove it from the iMac. Lift the left speaker straight up and remove it from the iMac.
    • Lift the left speaker straight up and remove it from the iMac.
Conclusie
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Sam Goldheart
436.525 Reputatie
547 handleidingen geschreven
iFixit Lid van iFixit
Community
134 Leden
15.638 handleidingen geschreven
Looks like an thow away product. !@#$ what an desaster. I saw an film on arteTV with the fownder of ifixit an the fight against the throwaway. I use my powerbook 10 years and repair it. my son got an ipod with a bad battery, i thought now problem just open and put a new in, but !@#$ where are the screws ...
micosch - Antwoord
products without screws to open ... are no product ... is rubish
micosch - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 37
Altijd: 1,395
