Ga door naar hoofdinhoud
iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement, Adhesive Strips: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    iMac Intel 21.5" Cardboard Service Wedge
    Koop
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iFixit cardboard service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • If you are not using an iMac service wedge, be very careful when installing and working behind the display—it can easily fall out and break if the iMac moves unexpectedly.
  2. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 2, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 2, afbeelding 2 van 2
    • Before you start placing strips, remove all of the old adhesive around the perimeter of the rear enclosure.
    • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
    • Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
    • After all the old adhesive is removed, carefully clean the area under the adhesive with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
    • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
  3. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 3, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 3, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 3, afbeelding 3 van 3
    • Start with the strip labeled 3 (or 03), which goes on the right vertical side of the rear enclosure.
    • Before you peel off any backing, line the adhesive strip up along the frame of the iMac to get an idea of where it goes.
    • Peel the short piece of backing off the back of the strip.
  4. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 4, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 4, afbeelding 2 van 2
    • Insert the tip of a spudger into the hole at the end of the strip from the side that still has a backing on it.
  5. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 5, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 5, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 5, afbeelding 3 van 3
    • With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
    • Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pulling up against the spudger to ensure the strip is taut, and stick it onto the frame.
  6. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 6, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 6, afbeelding 2 van 2
    • Once you've aligned the bottom half of the adhesive strip, peel the longer piece of backing out from behind the strip.
    • If the bottom half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  7. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 7, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 7, afbeelding 2 van 2
    • Align the upper half of the strip with the right edge of the rear enclosure, and stick it down.
  8. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 8, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 8, afbeelding 2 van 2
    • Use your finger to smooth Strip 3 along the right edge. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
    • Do not peel off the front adhesive backing yet.
  9. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 9, afbeelding 1 van 1
    • Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
    • Strip 2 on the top right
    • Strip 1 on the top left
    • Strip 5 on the left vertical
  10. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 10, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 10, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 10, afbeelding 3 van 3
    • The two remaining strips (4L and 4R) do not have guide holes and are more difficult to place than the previous ones. Before sticking them down, we recommend first setting them in their respective places on the iMac to get comfortable with their placement.
    • Grasp the red film pull tab on the 4R adhesive strip and pull to remove the backing from the strip.
    • Align the strip on the bottom edge of the rear enclosure, directly to the right of the middle screw on that edge.
    • Run your finger along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
  11. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 11, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 11, afbeelding 2 van 2
    • Repeat the previous step for the 4L adhesive strip, placing it along the left half of the bottom edge of the iMac.
    • Once you've applied all the adhesive strips, the iMac should look as shown in the photo.
  12. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 12, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 12, afbeelding 2 van 2
    • Gently lay the display in place over the iMac, and align it carefully.
  13. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 13, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 13, afbeelding 2 van 2
    • Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
    • The tape preserves the display's alignment, and allows you to safely swing the top edge of the display open to access the display cables.
  14. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 14, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 14, afbeelding 2 van 2
    • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
    • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 17.
    • Insert the display power cable into its socket on the logic board.
  15. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 15, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 15, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 15, afbeelding 3 van 3
    • Use a pair of tweezers or your other hand to gently insert the display data cable connector into its socket on the logic board.
    • Be sure to press it straight into the socket, and insert it completely.
    • Secure the metal retaining bracket on the display data cable downwards towards the logic board.
  16. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 16, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 16, afbeelding 2 van 2
    • Set the display back on the iMac's rear enclosure.
    • At this time, plug in your iMac, power it on, and test your repair before moving on to actually sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
    • When you are finished, shut the iMac down and unplug the power cord before you continue.
  17. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 17, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 17, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 17, afbeelding 3 van 3
    • Verify that your iMac is turned off and unplugged from power before you continue.
    • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
    • Remove the film from the 4R strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
  18. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 18, afbeelding 1 van 1
    • Repeat the previous step for the 4L strip.
  19. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 19, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 19, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 19, afbeelding 3 van 3
    • Reconnect the display power and data cables for the final time.
    • Remember to secure the metal retaining bracket on the display data cable.
  20. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 20, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 20, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 20, afbeelding 3 van 3
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
    • Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
  21. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 21, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 21, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 21, afbeelding 3 van 3
    • Remove the protective film from Strip 1 by pulling its tab straight up.
    • The film/liner may break if pulled too hard. Work carefully and make sure that there's no pressure on the display and that it doesn't pinch the strips.
  22. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 22, afbeelding 1 van 2 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 22, afbeelding 2 van 2
    • Likewise, remove the protective film from the strip that was paired with Strip 1.
  23. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 23, afbeelding 1 van 1
    • Repeat the previous two steps to remove the protective film from all the remaining adhesive strip pairs (labeled 2, 3, and 5).
  24. iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 24, afbeelding 1 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 24, afbeelding 2 van 3 iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement: stap 24, afbeelding 3 van 3
    • Remove the tape securing the display to the rear enclosure.
    • To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
Eindstreep
310 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.602 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.718 handleidingen geschreven
33 opmerkingen
Good Lord, why does Apple have to make it so difficult to upgrade or repair? There comes a point where design aesthetic just isn't worth it. Magnets, like I believe older iMacs use to attach the front glass, would have made it much easier. I'll take the extra bulk any day.
amiller77 - Antwoord
Have you actually done the replacement? It's actually pretty easy. Apple did everything they could to make it as painless as possible: the old adhesive separates without *any* residue, it doesn't rip apart, it doesn't make a mess. Things align like magic.
True, it could be easier. Like with the old color iMac SD. But since I don't take my iMac apart every day, doing this once or maybe twice in my computer's lifetime is a small price to pay for a *really* slim and good looking device.
Daniel Mores -
I had some issues with steps 21, 22 and 23 ... the tabs would rip off. After the third one I used the plastic card to gently create some space for the strip to escape.
Daniel Mores -
Hello! Tell me, what adhesive tapes are used! Length, width, thickness? On what basis are these tapes?
Oleg - Antwoord
Thank you for this fantastic guide, and all of the iFixit guides! Just finished this replacement using the iFixit Adhesive Strips/iMac Opener tool combo--everything worked very well, except that the iMac Opener tool did not particularly like the broken glass area of the display, which bent the plastic of the "pizza cutter" wheel a little.
One bit of helpful advice is to use extreme care when placing the replacement display back into the iMac. Make sure that you do not put the display back in at too great of an angle, or there will be a very noticeable gap at the bottom, between the display glass and the iMac frame. Adhesive strips are not forgiving, and rarely give multiple chances!
IT Helper - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 96
Afgelopen 30 dagen: 464
Altijd: 89,501
