Inleiding
Use this guide to upgrade your CPU.
Wat je nodig hebt
Unplug your iMac's AC cord along with any peripheral devices.
Lay your iMac face-down on a soft, clean surface as shown.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door.
Gently slide the black plastic RAM pull tab out from the RAM slot.
Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
In the proceeding steps, you will disconnect the following cables:
SD Board
Left/Right Speaker and Microphone
Audio Port
Wi-Fi Antenna
Right Temperature Sensor, Bluetooth/Ambient Light Sensor/Camera/Left Temperature, and Hard Drive Fan
CPU Fan/Ambient Temperature and Power Button
IR Sensor
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm fine-threaded screws
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
Peel the piece of tape covering the heat sink thermal sensor cable up off the logic board.
Carefully pull the CPU retaining bar away from the CPU socket.
Rotate the bar away from the logic board.
43 andere personen hebben deze handleiding voltooid.
11 opmerkingen
BTW, what's the most powerful CPU you can upgrade to? 21.5" 2428 logic board no.:820-2641-A. Also, can radeon 6750M be replaced with 6770M or even 6950/6970M?
Thank you
i7 2600s (65W) and 6770m, as I heard 6950 and 6970 have bigger size
imho
Andrew -
Managed to upgrade my 21.5" 2428 with a i7-2600 (not S!), it has a higher base clock frequency than the S.
Running well so far. Thanks for the guide!
how is the 2600 working after this years? any issues so far? thanks!
Hello, any info regarding the i7-2600? How is the iMac running? Thanks in advance
