Inleiding
Use this guide to replace the headphone/microphone jacks on your iMac.
Onderdelen
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Disconnect the audio port cable by pulling its connector toward the left side of the iMac.
Peel the audio port cable off the front face of the logic board.
5 andere personen hebben deze handleiding voltooid.
