Inleiding
Replace a broken AirPort card to regain Wi-Fi connectivity.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the flat end of a spudger to pry all three AirPort antenna cable connectors up from their sockets on the AirPort card.
9 andere personen hebben deze handleiding voltooid.
