Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Koppel je iMac's stroomkabel en alle andere aangesloten apparaten los.
Leg je iMac met het scherm naar beneden neer, op een zachte en schone ondergrond.
Maak de drie kruiskopschroeven (Phillips) los, die de toegangsdeur aan de onderkant van de iMac bevestigen.
Verwijder de toegangsdeur.
Deze stap is niet vertaald. Help het te vertalen
Gently slide the black plastic RAM pull tab out from the RAM slot.
Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
Slide the old RAM module(s) out of their slots in the RAM bay and set them aside.
Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay.
Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
Gereedschap gebruikt in deze stap:Heavy-Duty Suction Cups (Pair)$14.95-
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Slightly lift the top edge of the display out of the outer case.
Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
Pull the display data cable straight out of its socket on the logic board.
Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Pull the optical drive thermal sensor connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Disconnect the optical drive cable by pulling its connector away from the optical drive.
Remove the optical drive from the iMac.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
Pull the optical drive fan off the pins attached to the outer case.
Pull the optical drive fan connector out of its socket on the logic board.
Remove the optical drive fan from the iMac.
In the proceeding steps, you will disconnect the following cables:
SD Board and microphone
Left/Right Speaker
Wi-Fi Antenna
Bluetooth/Ambient Light Sensor/Camera/Left Temperature Sensor, Hard Drive Temperature Sensor and Hard Drive Fan
CPU Fan/Ambient Temperature and Power Button
IR Sensor
Pull the microphone cable connector toward the top edge of the iMac to disconnect it from the logic board.
Pull the SD board cable out of its socket on the logic board.
Disconnect the left speaker and right speaker cables by pulling their connectors toward the right side of the iMac.
Use the flat end of a spudger to pry both AirPort antenna connectors up from their sockets on the AirPort board.
Disconnect the hard drive fan by pulling its connector toward the top edge of the iMac.
Pull the hard drive thermal sensor cable out of its socket and toward the top edge of the iMac to disconnect it from the logic board.
Use your thumbnails on both sides of the Bluetooth/ambient light sensor/camera/left temperature connector to push it toward the top edge of the iMac and out of its socket on the logic board.
Pull the CPU fan/ambient temperature sensor connector toward the bottom left edge of the iMac and out of its socket on the logic board.
Pull the power button connector toward the bottom left corner of the iMac to disconnect it from its socket on the logic board.
Remove the piece of tape covering the IR sensor cable.
Use your thumbs to push the IR sensor connector out of its socket and toward the top edge of the iMac.
Pull the IR sensor board up from behind the front face of the outer case.
Remove the IR sensor and set it aside.
Remove the following seven screws:
Two 7 mm T10 torx screws
One 30 mm T10 Torx screw
Two 25 mm T10 Torx screws
Two 21 mm T10 Torx screws
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm fine-threaded screws
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
Remove the power supply from the outer case.
Remove the plastic wall that is installed directly to the right of the LED driver board.
Remove the plastic pressure wall installed next to the hard drive.
Slightly pull the logic board away from the back of the outer case, then lift it upward to clear the lower front face of the outer case.
Disconnect the audio port cable by pulling its connector away from the front face of the logic board.
If present, peel off the tape securing the hard drive SATA cable to the logic board.
Depress the locking mechanism and carefully pull the DC-In cable out of its socket on the back of the logic board.
Being careful not to damage the socket on the logic board, gently pull the hard drive SATA data cable straight out of its socket on the logic board.
Remove the logic board, minding any cables that may get caught.
Remove the strip of tape securing the GPU thermal sensor cable to the logic board.
Remove the following three screws:
One 4.2 mm T10 Torx screw
Two 5 mm T8 Torx screws
Grab the GPU thermal sensor cable connector and pull it straight up and out of its socket on the logic board.
Lift the GPU heat sink slightly and pull the GPU board out of its socket on the logic board.
Verwijder de vier 6.5 mm lange T8 Torx-schroeven, die de grafische kaart aan het koellichaam bevestigen.
Het is misschien nodig om een #1 schroevendraaier te gebruiken, om de houders van het koellichaam op zijn plaats te houden, wanneer je de T8 Torx-schroeven losdraait.
71 andere personen hebben deze handleiding voltooid.
20 opmerkingen
Hi everyone,
Which GPUs can you use as upgrades for this 2010 model? Mine has a Radeon 5670 512mb and I'd like something a bit more powerful...
Thanks!
lucky, i have a 256 mb card
Heh. I just replaced the 512mb 5670 card with the 256mb 4670 card.
Why, you might ask? Because of Mojave support. The 4670 is supported under Mojave but the 5670 is not…
One question:
i can put this GPU: NVIDIA GeForce GTX460M
on my iMac Mid 2011?
or i will have problems with the Drivers?
Wonderful guide! First time I opened a imac.
I need to replace the LCD cable connector on the motherboard. It is broken and it caused a short circuit on the motherboard. On the motherboard, underneath the grafic card, I've found a fried SMD inductance (L9000 on the motherboard) in the powerline of the grafic card. I restored the powerline with some solder leaving the inductance out. Should be no problem.
