Inleiding
Use this guide to replace a broken camera.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the two 5.2 mm shouldered T10 Torx screws securing the camera board to the outer case.
Één andere persoon heeft deze handleiding voltooid.
