Inleiding
Use this guide to replace your Bluetooth board.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up from its socket on the Bluetooth board.
4 andere personen hebben deze handleiding voltooid.
