Inleiding
Use this guide to replace a faulty SD Board.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the tip of a spudger to push the SD board cable connector out of its socket.
Één andere persoon heeft deze handleiding voltooid.
