Ga door naar hoofdinhoud
iMac Intel 21.5" EMC 2308 RAM Replacement
Wat je nodig hebt
  1. iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: stap 1, afbeelding 1 van 2 iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: stap 1, afbeelding 2 van 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
    In order for the logic board to come out cleanly, one should remove the RAM at the end of this step.
    kevmacmills - Antwoord
    Definitely! The author should make this as a step in the description (because not everyone reads Comments)
    finnik2d - Antwoord
    Just did this procedure and the RAM must absolutely come out for the logic board to come free later.
    matt - Antwoord
  2. iMac Intel 21.5" EMC 2308 RAM Replacement, RAM: stap 2, afbeelding 1 van 1
    • Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
  3. iMac Intel 21.5" EMC 2308 RAM Replacement: stap 3, afbeelding 1 van 2 iMac Intel 21.5" EMC 2308 RAM Replacement: stap 3, afbeelding 2 van 2
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
Conclusie
111 andere personen hebben deze handleiding voltooid.
Één opmerking
There needs to be a little bit of important discucssion about getting the new RAM properly seated into the slots. Otherwise, great instructions!
Mary - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 110
Altijd: 88,823
