Inleiding
Replace a burned-out optical drive fan to keep temperatures down.
Onderdelen
Geen onderdelen opgegeven.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
3 andere personen hebben deze handleiding voltooid.
