Inleiding
Replace a broken hard drive fan to keep temperatures down.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the following four screws securing the power supply to the outer case:
Two 22.2 mm fine-thread T10 Torx
One 25 mm coarse-thread T10 Torx
One 9 mm coarse-thread T10 Torx
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
Pull the left and right speaker connectors toward the right side of the iMac to disconnect them from the logic board.
Disconnect the following cables by pulling their connectors toward the top edge of the iMac:
Camera cable
Hard drive thermal sensor
Hard drive fan
Microphone
Disconnect the following cables by pulling their connectors toward the right edge of the iMac:
Ambient temperature sensor
Bluetooth cable
Remove the single 13mm T10 Torx screw securing the hard drive fan to the outer case.
Remove the hard drive fan from the outer case.
6 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
can you tell me where to buy this fan?
I would not classify this as a “very easy” repair. If you have pulled apart your iMac before, it is manageable, but this is a moderate to difficult repair at least. Other than that, this is a helpful guide and quite necessary for doing this repair. If only the fan was available from ifixit!
