Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
This guide is an internal prerequisite that should remain unpublished.
Onderdelen
Geen onderdelen opgegeven.
  1. If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
    • If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
  2. Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
    • Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
  3. Manta schroevendraaierset
    112 bitjes voor elke reparatie.
    Upgrade Your Toolbox
  4. Peel the cable retainer off the side of the CPU fan.
    • Peel the cable retainer off the side of the CPU fan.
    • If the tape on the cable retainer loses adhesion, remove the existing foam tape and either use double-sided tape or glue to reattach it to the CPU fan.
    • Remove the CPU fan from the outer case, minding any cables that may get caught.
  5. De-route the left speaker cable from the clips securing it to the outer case.
    • De-route the left speaker cable from the clips securing it to the outer case.
  6. Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer. Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
    • Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,719
