Ga door naar hoofdinhoud
iMac Intel 20" EMC 2105 and 2118 RAM Replacement
Wat je nodig hebt
  1. iMac Intel 20" EMC 2105 and 2118 RAM Replacement, Access Door: stap 1, afbeelding 1 van 2 iMac Intel 20" EMC 2105 and 2118 RAM Replacement, Access Door: stap 1, afbeelding 2 van 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac Intel 20" EMC 2105 and 2118 RAM Replacement, RAM: stap 2, afbeelding 1 van 1
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 20" EMC 2105 and 2118 RAM Replacement: stap 3, afbeelding 1 van 1
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
Conclusie
To reassemble your device, just follow these instructions in reverse order.
62 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 36,912
