Inleiding
Use this guide to remove your heat sink.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Loosen the two captive Phillips screws securing the access door to the iMac.
Remove the access door from the iMac.
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Remove the four 8 mm with 2 mm thick head coarse-thread T10 Torx screws securing the display to the rear case.
Remove the 30 mm T10 Torx screw securing the left speaker to the rear case.
Pull the SATA data cable connector away from its socket on the logic board.
Pull the power button cable connector up off its socket on the logic board.
Remove the following screws securing the heat sink bracket to the heat sink and logic board:
Four 7.8 mm T8 Torx screws.
Two 6 mm T8 Torx screws.
5 andere personen hebben deze handleiding voltooid.
