Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Loosen the two captive Phillips screws securing the access door to the iMac.
Remove the access door from the iMac.
Remove the following four screws:
Three 6 mm T8 Torx.
One 8 mm T8 Torx.
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99-
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape(it is ok to toss this) wrapped around the microphone and camera cables.
Remove the two 4.8 mm T6 Torx screws securing the display data cable to the logic board.
Grab the display data cable connector by its black tab and pull it straight up off the logic board.
Inverter cable on 24inch iMac pulls off to the left.
Pull the inverter cable connector straight up off its socket on the logic board.
Peel back the aluminum EMI tape from the two vertical edges of the display.
Gereedschap gebruikt in deze stap:TR10 Torx Security Screwdriver$5.99-
Remove the four 8 mm with 2 mm thick head coarse-thread T10 Torx screws securing the display to the rear case.
Lift the display from its lower edge and pull it toward yourself to peel off the EMI shield attached to its top edge.
51 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Please be careful at step 5. This is because the wiring attached to the microphone is very delicate and might snap when you are wiggling the bezel free from the rest of the computer. I did this and spent a lot of time soldering back the thin microphone wires. Pull the bezel away carefully, taking care not to snap any of the wires.
