Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
Push the spudger away from the AirPort card to disconnect the AirPort antenna.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Slightly lift the AirPort bracket off the logic board.
De-route the AirPort antenna through the slot in the AirPort bracket.
Use a spudger to slide the PRAM battery out from under its socket's metal clip.
Één andere persoon heeft deze handleiding voltooid.
