Inleiding
Use this guide to replace your CR2032 PRAM battery.
Wat je nodig hebt
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Één andere persoon heeft deze handleiding voltooid.
