Wat je nodig hebt
Remove the following three screws:
One shouldered 12.4 mm Phillips.
Two 7 mm T10 Torx.
Lift the hard drive slightly and disconnect the hard drive thermal sensor connector.
Bijna klaar!
Conclusie
My model have 3 phillips screws, no torx
Nicolas Varney - Antwoord
Same here. No torx. Very easy to do. Not a moderate difficulty at all. As long as you don't rush anything and ease the electronics out. Did I say ease? I meant "tease." Tease the connectors out. Slow and steady. Easy as pie.
airira - Antwoord
