Inleiding
The PRAM battery is located underneath the logic board.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
Lift the edge of the PRAM battery slightly with your fingertip and use a spudger to slide the PRAM battery out from under its socket's metal clip.
3 andere personen hebben deze handleiding voltooid.
