Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
iMac G5 17" Model A1058 RAM Replacement
Wat je nodig hebt
  1. iMac G5 17" Model A1058 RAM Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 RAM Replacement: stap 2, afbeelding 1 van 3 iMac G5 17" Model A1058 RAM Replacement: stap 2, afbeelding 2 van 3 iMac G5 17" Model A1058 RAM Replacement: stap 2, afbeelding 3 van 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 RAM Replacement, RAM: stap 3, afbeelding 1 van 3 iMac G5 17" Model A1058 RAM Replacement, RAM: stap 3, afbeelding 2 van 3 iMac G5 17" Model A1058 RAM Replacement, RAM: stap 3, afbeelding 3 van 3
    • Rotate each of the two RAM retaining arms away from the RAM chip.
    • Pull the RAM chip straight away from its socket.
    • Repeat this process for the other RAM chip.
    • Be sure the RAM arms are fully rotated away from the RAM socket before reinstalling any RAM chips.
Conclusie
39 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - Antwoord
Can i get 6 or 8 gigs ram?
frederikchalmer - Antwoord
Do both the ram slots have to have ram in them
Gary Wayne - Antwoord
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 24
Altijd: 30,268
